Out application uses MapSuite 10. A while back we were having problems with certain GeoTiff files that would not render in our application. It ended up being a tiled GeoTiff which is not supported in our version (see the issue here). At that time we were advised that we could use QGIS and export the GeoTiff as “rendered”, then use it in our application, and that works. Recently we tried that with a GeoTiff and it did not work. I don’t know if it is a tiled GeoTiff or not. Could you please have a look and see why it will not render? The GeoTiff can be downloaded here.
Steve
