StreetsNotLabeled.pdf (798.1 KB)
MapSuite Team,
I have attached a document which shows streets that should be labeled but are not labeled.
I saw another topic from February (How to make labels always show up, not dependent on scales?) stating exactly this same issue. However, there was no resolution stated that I could find.
All of my TextStyle per ZoomLevel’s are set properly. I’ve concluded that this has something to do with Scale as well as Height/Width of Tile as specified for LayerOverlay. The attached document shows several examples of some streets being labeled, but not others. When you look at the map it appears that there is plenty of room for the label. When a Zoom In/Out is performed the label will appear.
Below are the TextStyle Properties. I’ve attempted all possibilities on these properties and nothing helps.
Any suggestions?
Dennis
GridSize=512
SuppressPartialLabels=true
LabelOverlappingRule=NoOverlapping
LabelDuplicateRule=NoDuplicateLabels
LabelAllLineParts=false
DrawingLevel=LabelLevel
SplineType=StandardSplining
TextLineSegmentRatio=250
FittingLineInScreen=true
MaxNudgingInPixel=0
NudgingIntervalInPixel=0
ForceHorizontalLabelForLine=false
